100W power adaptor - Blimk
100W power adaptor mini vobot connect still HP monitor blinking why ?
Hi,
Thank you for reaching out. I’m sorry to hear you’re experiencing flickering issues with your HP monitor while using the 100W power adapter.
To help us identify the cause and provide a solution, please try the following Troubleshooting Steps:
Check the Power Input: Please ensure the 100W adapter is plugged into the PD (Power Delivery) port of the Mini Dock, and the Mini Dock is connected to your laptop via the original full-featured USB-C cable.
Verify the HDMI Cable: Monitor blinking is often caused by a low-bandwidth cable. Are you using an HDMI 2.0 or 2.1 cable? If possible, please try testing with a different HDMI cable to rule out a cord defect.
Check Laptop Power Requirements: Some high-performance laptops require a significant amount of power. Even with a 100W adapter, if the laptop is under heavy load, it may cause a momentary power drop to the HDMI output.
Display Settings: Try lowering the Refresh Rate (e.g., from 144Hz to 60Hz) in your Windows/Mac display settings to see if the blinking stops.
Could you also please provide the following details?
Your Laptop Model (e.g., MacBook Pro M2, Dell XPS 15).
Your HP Monitor Model.
Your Order ID for warranty reference.
Once we have this information, our technical team can provide a more specific firmware or hardware solution for you.
Best regards,
Vobot Team
