Ethernet port connection not alive on connected PC
I’m using and enjoying a lot my little desktop companion. However, I have started to experience an issue with the ethernet port. Although the port is connected and has network activity with lights, its connection “status” is not passed to the connected laptop.
I have tried connecting the Vobot usb-c cable to the computer into different ports, but no change.
I’ve tested the network cable directly to the laptop (using a usc-c dongle), and the laptop sees it.
If I connect the network cable on the usb-c dongle into the Vobot usb-c port, the laptop then sees the ethernet as being connected. So the Vobot to PC connection works.
As a last resort, I have factory reset the Vobot and no better results.
Is there anything else to try?
Thanks in advance!
Hi,
Thank you for reaching out and for providing such a thorough breakdown of your troubleshooting steps. We truly appreciate the effort you’ve put into testing the ports and even performing a factory reset.
Based on your detailed analysis—specifically that the laptop recognizes the connection through a separate dongle but not directly through the Mini Dock’s Ethernet port—it appears there may be a hardware defect with the internal Ethernet controller of your specific unit.
Since you’ve already tried all the standard fixes, we want to resolve this for you immediately so you can get back to enjoying your “desktop companion.” We would like to send you a brand-new Vobot Mini Dock as a replacement.
To proceed, could you please send an email to [email protected] with the following details?
Order ID (from your purchase)
Full Shipping Address
Contact Phone Number (required for the courier)
Once we receive your email, we will prioritize your shipment and provide you with a new tracking number as soon as possible.
Thank you for your patience and for being a part of the Vobot community!
