Hi, I’m trying to set up my vobot dock mini. I’m on the stage where I need to connec to http://10.9.8.7. Unfortunately the connection just times out. What do I do?
For the problem that you cannot access the link http://10.9.8.7, it may be the following:
The phone is not connected to the correct Wi-Fi. The hotspot opened by Mini Dock cannot access the network, so sometimes the phone automatically connects to other Wi-Fi. Please make sure that when the browser opens 10.9.8.7, your phone Wi-Fi is connected to the hotspot of D1. You can also try to use a laptop to try to configure the network.
Your phone is opening the VPN software. You can try to close the VPN software and try to configure the network for Mini Dock again. Restart the VPN software after the configuration is completed.
