Default clock theming/editing
Is there a way to change the style of the default clock? It seems baked into the firmware, anyway, to get a version of the firmware where we can customize/style/build our own clocks?
If you are talking about the LED clock display style on the left side of the screen, due to hardware lamp bead limitations, only the brightness can be modified.
If you need to display other digital information, you can refer to the public API documentation: Peripherals - Vobot Mini Dock
If you have any questions about product use, please feel free to contact us.
