Just started playing with my Mini Dock for the first time. Hardware looks amazing, but the app development is frustrating. REALLY frustrating, specifically because as I was trying the examples of LVGL, when my device restarted to run the app, it got stuck in a boot loop!
Tried (and succeeded) to refresh the firmware, but that doesn’t erase the user data/apps, so it’s still stuck in the boot loop even though the firmware updated.
Also tried holding down the back button for 15 seconds, but nothing.
Can’t get to the web settings because again, it’s rebooting before connecting to the web, and I can’t get to the settings page to enable it to be visible to the desktop.
Also tried going into Thonny and using it to delete the app folder on the device, but it can’t connect because the dock keeps rebooting before it does.
Tried connecting via Thonny with the device in Firmware Update mode thinking that would at least stop the app from crashing things, but Thonny says the device is busy and can’t connect that way either.
So I’m effed it seems. Any ideas on how to resolve this, or is this thing bricked short of me opening it up and attaching a JTAG or something (which I don’t actually have/know how to do anyway.)
