Can you make this dock-app-bundler tool take command line arguments too? It would sure help to automate this part of the building of apps. I have FOUR of these little guys now and it can get tedious to do this all with the GUI. I’ve even bundled the wrong app into the wrong .vbt on accident before (or given it the wrong version). CLI (script) would solve that problem; especially if I let an LLM do the work.
Thank you for the thoughtful suggestion! Adding CLI arguments to the Dock App Bundler could make repeat builds easier to automate and help reduce manual errors—a useful improvement for developers. We’ve shared your feedback with our development team for evaluation and will post updates in this thread as we make progress.
Awesome! I was literally just thinking about trying to reverse engineer the .exe and a .vbt to make my own CLI version of this. I figure it can’t be all that complicated under the hood and is probably some kind of .zip file archive as many tools re-purpose (lzh, .epub, etc.) But now I’ll leave that to the experts as I’m sure it’s fairly trivial to add argv and argc to the .exe ![]()
One useful detail to ask for alongside argv/argc is a fully non-interactive mode: explicit --app path, --version, --output, and --yes/–overwrite flags, plus clear exit codes and no GUI dialogs. That would make it safe to call from a script or LLM and would catch wrong-app/wrong-version mistakes before a .vbt is written. I would not assume the .vbt is just a renamed zip without checking; the format may include a manifest or structure the bundler validates.
