Firmware v1.2.5 Now Live!
Dear Vobot Community,
Following up on our previous announcement regarding the Todoist integration, we are excited to share that our R&D team has successfully completed the development and testing for the latest fix.
Firmware version 1.2.5 is now officially released!
What’s New in v1.2.5:
  • Todoist API Migration: We have fully adjusted the Todoist app to support their latest API version. The “resource retrieval timed out” error is now resolved, and your tasks should sync seamlessly once again.
  • System Stability Fix: We identified and fixed a specific bug that caused a black screen when entering the “Locale” settings. This was rooted in a timezone synchronization issue and has been corrected to ensure a smoother navigation experience.
How to Update:
You should see a firmware update pop-up on your Vobot Mini Dock screen shortly. Alternatively, you can manually check for updates via: Settings >>> My Device >>> Software Update
We want to thank you all for your patience and for the detailed feedback that helped us identify these issues quickly. It is your active participation that helps us make the Mini Dock better every day.
If you encounter any issues after the update or have further suggestions, please feel free to drop a comment below or contact us directly.
Happy Docking!
Best regards,
Vobot Team
