My first app on Vobot - HK Weather
I’ve just published my first app for Vobot mini-dock, called HK Weather. It’s a weather app showing whether information from Hong Kong Observatory. It shows current weather information as well as 5-7 days forecast. If you have an indoor temperature/humidity sensor, the app is able to grab the data and show it too.
If you’re in Hong Kong and would like to check it out, you can download it from the link in Apps Market below:
https://app.myvobot.com/app-detail/HK%20Weather
Source codes can also be found here:
Dear Andy,
Thank you so much for sharing your app HK Weather! It is a very useful tool that provides users with weather information in Hong Kong, especially when combined with data from indoor temperature and humidity sensors!
We encourage you to continue exploring the fun of programming and look forward to more of your works in the future. At the same time, we also hope that other customers can be inspired by you to join the ranks of programming and share their applications and ideas.
Thank you again for sharing!
Best wishes,
Vobot Team
Well done! Andy, Weather forecasting, a leap from the built-in weather App of just showing the current weather
This app is very helpful to me, thank you
You’re welcome! I thought it would only be useful to me. Never thought someone else would really use it here. Anyway, if you have any suggestion for improvement or bug report, please feel free to let me know.
Thanks!
