PC H/W Monitoring app not opening
Hello everyone. I just got my mini-dock and I am trying to use the hardware monitoring part app on the dock. I followed the guide and downloaded Aida64 and the monitoring app, but when I use the monitor.exe file, the program does not open. what am I doing wrong? Is anyone else experiencing this? what am I doing wrong?
For the problem you encountered, the following reasons may be the cause:
  1. The .exe file is damaged. You can try to delete the file and then re-download the executable file (computer_monitor.exe). Download address: https://vobot.oss-us-west-1.aliyuncs.com/firmware/mini_dock/download/windows/computer_monitor.exe (If your computer is Windows system, .exe file only supports Windows system)
  2. Insufficient permissions. Please try to run computer_monitor.exe with administrator permissions
  3. Antivirus software may block applications. Try to temporarily disable them to see if the program can be opened
