Sports (Hockey)
Hi there,
I may not be understanding this completely, but I can not seem to figure out the formatting to get teams to show up. Can someone give me an example of the format I should be using. Looking at the example it gave me in the app I did this (fla, nhl; vkg, nhl)
The current configuration items of the Hockey APP are used to configure the events of the hockey league, not to select a specific team. Regarding the teams you display, you can enter the Hockey APP on the Mini Dock and select the specific team you want to display. I hope my answer can help you.
If you have any questions, please feel free to contact us
That makes sense. after I put in the ‘nhl’ as the identifier it started getting data. Thank you for your help with this, I apricate it.
