Time setting problem
The time displayed does not match the actual time Why not just allow us to set the time?
In order to reduce your operations, Mini Dock will automatically synchronize the time of the city you set the weather app. If it is not synchronized, please check whether the city you set is correct. You can also feedback your city to us and we will further verify it.
