Dear Vobot Community,
We have recently received reports regarding a “resource retrieval timed out” error when attempting to use the Todoist integration on the Vobot Mini-Dock. We would like to sincerely apologize for any inconvenience this may have caused.
The Issue: After a thorough investigation by our technical team, we found that Todoist has recently undergone a major API version iteration, officially deprecating the older version. As a result, the current request protocols integrated into the Mini-Dock firmware are no longer able to fetch data, leading to the timeout notification.
Our Solution: Our R&D team is currently prioritizing a new firmware update to adapt to the latest Todoist API. We are working to ensure that the new integration is stable and fully functional.
What You Can Expect:
Timeline: We are aiming to complete testing and deployment as soon as possible.
Notification: Once the internal testing is successful, we will post an official announcement here on the forum.
Update Method: You will also receive a firmware update pop-up directly on your Mini-Dock device as soon as the version is pushed to the production environment.
If you have any other questions or need further assistance with your device, please do not hesitate to reach out to us. Thank you for your continued support and patience as we resolve this!
Best regards,
Vobot Team
