My cpu does not have a usb c socket, my monitor is usb c. If i connect my monitor to one of vobots usb c’s and i connect a hdmi display cable to the display port to my cpu, would it be possible to connect the external monitor to my cpu?
Or just buy and use a HDMI to Type-C /DP to Type-C connector cable.
Your computer does not have a USB C slot, which means your computer interface does not support display alt mode. Only when it supports this mode can the video stream be output to the HDMI interface. So none of your solutions can connect an external monitor to your computer.
If you have any questions about the product, please feel free to contact us.
