Mini Dock 1.0.5 New Firmware Released & OTA Problem Solution
Hello friend,
Thank you for your support and trust in Vobot Mini Dock. This update is to inform you about the latest firmware 1.0.5 released for Vobot Mini Dock and about the OTA-related bugs and their solutions.
Issue Description:
If the Wi-Fi name (SSID) that the Mini Dock is connected to contains non-ASCII characters, you may encounter problems when performing OTA updates. ASCII characters include standard English characters, numbers, and common symbols (such as A-Z, a-z, 0-9, !@#$%^&*, etc.).
(For a complete list of ASCII characters, please refer to: https://www.asciitable.com)
Solution:
To avoid potential inconvenience in the future, we recommend that you re-flash the firmware through the webpage we provide to resolve this issue and upgrade to the latest version of the firmware. ( Please refer to: Firmware Burning - Vobot Mini Dock )
Additional Tip:
This solution also applies when developing custom apps using the Mini Dock. If the Mini Dock fails to start up properly or exhibits abnormal behavior, you can restore normal functionality by reflashing the firmware (this operation will not erase your saved configurations, such as weather, stock information, etc.).
New Firmware Version 1.0.5 Release Note:
We have released a new firmware version 1.0.5, which you can upgrade by reflashing via the webpage(Please refer to: Firmware Burning - Vobot Mini Dock ). This version includes the Todoist app, adds an application management interface, fixes issues with displaying stock price units, and includes other optimizations.
Vobot App Gallery has also been launched simultaneously. You only need to update the latest firmware version 1.0.5 to download and upload apps on the Vobot App Gallery. Many interesting Apps are available now. Go and check the ones that you want to try! You are welcome to make your ideas alive.
(Vobot App Gallery: https://app.myvobot.com/)
(How to download and install the App: Download Apps - Vobot Mini Dock)
In order to make your operation more convenient, we have recorded a reference video, hoping to help you. Video link: https://youtu.be/gtSlzD5E9cM
We sincerely apologize for any inconvenience this may have caused and appreciate your understanding and support. If you encounter any issues during the process or have any questions, please feel free to contact us.
Warm regards,
Vobot Team
Heck is the webpage where I can download / firmware update? I see great instructions :slight_smile:
I found it, nevermind
