Moon Calendar is not working
I am getting Failed to get weather data, Please check your network connection. It was working before.
Hi,
Thank you for bringing this to our attention, and we apologize for the temporary disruption. Our engineering team looked into this immediately. The issue was caused by a temporary security handshake failure (TLS handshake error) between the device and the third-party weather service provider ($wttr.in$).We have already deployed a fix to bypass this issue and restore normal data fetching.
How to fix it on your device: The update is now live in the Vobot App Gallery. To get your Moon Calendar working again, please follow these simple steps: Open the Vobot configuration page on your phone. Find the Moon Calendar app and click Upgrade/Update. Once the app is updated, it will automatically reconnect and display the data properly. Please let us know if you encounter any further issues after the upgrade!
Best regards,
Vobot Team
That worked, thanks for your quick response
