Time Display dies
Hi Vobot team and community,
I’ve noticed that the LED dot display on my Vobot Mini Dock seems to be fading over time. Some of the dots no longer light up, even after adjusting the brightness settings.
Is this something that only I’m experiencing, or have other users noticed the same issue? Has anyone found a solution, or is this a known hardware problem?
Thanks in advance for any feedback!
Hi out1974,
Thanks for the detailed description, and sorry to hear about the display. Some LED dots staying dark even at higher brightness settings is not expected behavior for the Vobot Mini Dock, so we’d like to take a closer look at your unit.
Could you record a short video showing the issue and email it to [email protected]? If possible, please film the display at a few brightness levels so we can see which dots are affected.
In the email, please also let us know:
  • How the device is powered (e.g. USB adapter, computer USB port, power bank)
  • The power adapter’s specifications (output voltage and current as printed on the label, e.g. 5V/2A); a photo of the label works too
Once we receive it, our team will review it and follow up with you by email on the next steps.
Best regards,
Vobot Team
Worth doing a quick power sanity check before you film the video: try a different USB adapter and cable, ideally a known-good 5V/2A or higher supply, and see whether the same dots stay dark. Insufficient or sagging power can make some segments look dim, but dots that never light at any brightness usually point to the LED matrix or its driver rather than settings. Either way, noting the adapter you used when you email support will help them rule that out.
