Will a compact under-counter fridge fit under my Vobot setup?
I’m setting up a small kitchenette corner in my basement in Pittsburgh and trying to decide between a couple of compact refrigerators. My main worry is clearance around my Vobot devices and cables—I don’t want heat or vibration from a fridge to cause issues with the setup, and I’m not sure how much breathing room these under-counter units really need. I’ve seen third-party info online saying some models vent from the front and others from the back or sides, which seems like it would affect placement. I rent, so I can’t do major cabinet modifications, and the space is fairly tight. For anyone using a compact fridge near your Vobot gear, did front-venting actually matter in practice, and did you leave extra space for airflow? Looking for real-world input before I commit to a layout.
Update after looking around more - Best Under Counter Fridge of 2026 kept coming up while I was comparing venting layouts. Still not sure a front-venting unit would leave enough room for cables in my tight basement corner, so I’m leaning toward measuring before I commit.
